The main element had 2 options-small burner, or large. the small burner sopped working, when the large burner was on, dark center-glowing red outer edge. I ordered a new main element (part AP3960181-316418401) and replaced it.... element will heat up after a few minutes, but will shut down... if it's not the element, what is not working properly?
