Need part number of circuit board for Kenmore Elite Dual Gas Range. Model 05 393G2 311 C970-445681 Serial NF2015764 (These are the numbers on the oven. I live in Canada. Sometimes Mod Numbers are changed for the country it is shipped to. I hope you can still help.) The old board has 318045069 Rev. A on it. when cooking turkey, I heard popping noises, then the smell of burnt wiring.
Please advise if this is a circuit board problem or advise what else I should be troubleshooting.
Current Circuit Board has the following numbers: 318045069 Rev A.
Looking forward to all responses. Hopefully inexpensive to fix. Thanks.
Hi kedsng, In case you still have it not fixed: Kenmore Elite (it's Frigidaire) Dual Gas Range. Model would be the 2nd line: C970-445681 >when cooking turkey, I heard popping noises, then the smell of burnt wiring. - looks like it's L-shaped big element on the board (close to P8) as it's usually not soldered properly. I have it as 318183403, you can repair it at Refrigerator Water Filters | GE | Whirlpool | Maytag | KitchenAid | Reliable Parts for $160 - 3 weeks; Also they have it as 318198408 for $594.10 I'm waiting also what Sears parts department will write to me (completed the parts inquiry form on the website). Got it - it's $535.xx at Sears. Please let me know if you have any info to share. Thanks, Gennady
