marywill
#1 Posted : Tuesday, November 25, 2008 7:10:53 PM(UTC)
marywill
I had turned on the self cleaning mode. When the oven was done cleaning and went into the cooling down mode, the readout went to E1 F-5. I cannot get the oven to unlock. I cannot get it to turn on or anything. I have shut off the power to the oven from the main breaker - but that did not help. What part has gone out?:confused:
libertyappl
#2 Posted : Wednesday, November 26, 2008 7:08:22 AM(UTC)
libertyappl
#3 Posted : Wednesday, November 26, 2008 8:19:31 AM(UTC)
Here is your parts breakdown
Model Search
Here is a good link, check out #1, yours looks like the motor type of lock buy the wiring diagram calls it a solenoid so I am unsure which it is.
http://www.applianceaid.com/elecrange.html
And here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208053304.pdf
If the sensor goes open the unit thinks it is still hot so the door will not open. Sensor should measure approximately 1000 ohms at room temperature.
If you cannot figure out how to open it perhaps try private mailing or email to his site, Kayakcrzy, he knows how to open just about everything
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
