Discuss
Maytag oven not heating
 in
My 2 year old maytag oven would not heat properly this am. I had set it to heat up while
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag oven not heating
  #1 (permalink)
Old 10-09-2007, 03:27 PM
moongidget moongidget is offline
Junior Member
moongidget is on a distinguished road
Default Maytag oven not heating
Model Number: mer5765raw   Brand: Maytag   Age: 1 - 5 years
My 2 year old maytag oven would not heat properly this am. I had set it to heat up while we were sleeping, expecting it to be at the right temp when I woke up. But after an hour and a ruined batch of muffins, it was still only 200 degrees. I turned off the delay bake function and it still would not heat up properly. Also, the oven thermometer was not even registering 150. Is this the element that needs replacing? I am not at home to check, but I have a similar unit to the model # listed above. It has a 5 burner cooktop, and a oven rack system that allows you to take out 1/2 of the upper rack for cooking large items.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-22-2008, 09:05 AM
afergus afergus is offline
Junior Member
afergus is on a distinguished road
Default
I also have a 2 1/2 year old Maytag with the same problem. I removed the bottom plate and found the element split in two. I replaced the element and still the oven will not heat up. Does anyone have any suggestions on what I should replace next?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Range top and oven heating Emily Oven Repair (including Ranges and Cooktops) 1 09-14-2007 11:07 PM
Oven will not stop heating RBowman Oven Repair (including Ranges and Cooktops) 1 09-10-2007 07:13 PM
Maytag - Dryer not heating timer mode freebird Dryer Repair 0 08-16-2007 12:06 PM
Oven not heating properly harry-homeowner Oven Repair (including Ranges and Cooktops) 1 08-04-2007 11:44 PM
oven not heating ljticeman Oven Repair (including Ranges and Cooktops) 1 08-01-2007 04:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
