| » Viking oven - how do I replace the bottom oven element |
Model Number: RE3003W-1 Brand: -other- Age: 5 - 10 years
I need instructions on how to remove existing broken bake element and to install the new one.
Your model number does not yield any parts search result. I'll venture a guess. If you cannot see the element, You can probably access it by removing two or three screws on the bottom plate inside the oven. Make sure you unplug the oven first, or turn it off at the breaker: a lot of ovens still have 110 volts at one of the terminals of the elements, even when the switch is off.
| Display Modes | |
| Replace Bake Element, Remove Oven Bottom | jcarbeck | Oven Repair (including Ranges and Cooktops) | 3 | 01-07-2010 12:53 AM |
| replace the oven ignitor on a viking range | jm81204 | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 07:37 AM |
| Oven bottom element will not shut off | Wendy Myatt | Oven Repair (including Ranges and Cooktops) | 6 | 11-11-2009 04:03 PM |
| Bottom oven element not working | lavrjn | Oven Repair (including Ranges and Cooktops) | 0 | 11-02-2009 06:07 AM |
| Oven bottom element will not shut off | Wendy Myatt | Oven Repair (including Ranges and Cooktops) | 1 | 06-01-2009 07:29 AM |
