During the cleaning cycle the stove locked up and lost indications on the control panel. Through looking at solutions to others problems on this same unit, I took the suggestion to check the thermal fuse behind the control panel which I found to be bad. I removed and replaced it and the oven came back to life at least the bottom oven works.
I still can not get the upper oven to heat up. All indications are good other then it is not heating up. The element stays cool.
What do you suggest next??
