I have a GE Profile Dual Convection Oven and recently when you open the door when the oven is in convection mode, the fan doesn't shut off. We can also detect a slight burning smell not related to food. Could this be a switch (door plunger) issue? Any help would be appreciated.
Thanks! Bruce
Originally Posted by: brosenberg69 I have a GE Profile Dual Convection Oven and recently when you open the door when the oven is in convection mode, the fan doesn't shut off. We can also detect a slight burning smell not related to food. Could this be a switch (door plunger) issue? Any help would be appreciated.
Thanks! Bruce Still looking for some help with this! Anyone have any ideas? Thanks!
Hi, I have this exact same problem with my GE Profile Dual Convection oven. Were you able to repair the problem? If so, how? Any help would be appreciated, thanks. Bob
Originally Posted by: bjg99 Hi, I have this exact same problem with my GE Profile Dual Convection oven. Were you able to repair the problem? If so, how? Any help would be appreciated, thanks. Bob We had a repairman out today who replaced a control board and said the oven was fixed. I guess there was a relay on the board that got welded shut. Well I got home tonight and tried it out and nothing had changed. The fan still runs when you open the door and we are getting a burning smell again. We got the burning smell originally when this issue started. It is kind of like an electrical burning smell. Not food burning smell. So, clearly there was a problem as the relay was "toast" but I am guessing there is still something wrong - or at least another issues in addition to the relay on the board.
Thanks for the reply. I have the same problem. Convection fan spins very fast and I smell a definite electrical burning smell. Fan does not shut off when door is opened either.
I haven't called a repair man yet. I'm a stubborn electrical engineer and always try to fix things myself first (mostly because I'm cheap too).
If I figure anything out I'll post it on here.
