| » Bake Or Broil Not Workink |
Model Number: RF302BXGW0 Brand: Whirlpool Age: 5 - 10 years
NEITHER THE OVEN OR THE BROIL WORK BOTH WENT OUT AT THE SAME TIME GOOD POWER GOING IN NOTHING TO EITHER ELEMENT HOW DO I TELL IF ITS THE SLECTOR SWITCH OR THE THERMOSTAT?
tomnshirleyhart@roadrunner.com Ads By Google Related Models |
Buy yourself a digital multimeter.
You can get a decent meter for under $20.00, you do not need fancy. It is nice if the leads are a couple feet long. If it saves buying one unnecessary part, it has paid for itself. You can then unplug the unit and check for continuity. There is a good sticky on using a meter at the start of this forum.
__________________
Try takeing the 2 wires off the thermal fuse, #23 on the chasis list, and put them together, and see if it works. If it does, do not run it like that. Tom ********************************************
Forgot to add the following
Wiring diagram https://www.servicematters.com/docs/...%203196804.pdf Parts breakdown Model RF302BXGW0
__________________
| Display Modes | |
| Will Broil not Bake | assistance | Oven Repair (including Ranges and Cooktops) | 1 | 12-26-2009 04:11 PM |
| Oven bake/broil not working after bake element replacement | J Justin | Oven Repair (including Ranges and Cooktops) | 1 | 11-05-2009 04:36 PM |
| Replaced bake element, now won't bake/broil | mvwa | Oven Repair (including Ranges and Cooktops) | 0 | 10-18-2009 12:55 PM |
| Broil but no bake | bobdole | Oven Repair (including Ranges and Cooktops) | 1 | 12-26-2008 11:22 AM |
| broil no bake | tag | Oven Repair (including Ranges and Cooktops) | 2 | 12-20-2008 03:52 PM |
