My maytag gas range bake option will not work. The broiler works. The bake ignitor does not glow. It has continuity and to make sure i installed it on the broiler and it works. The oven (thermo) sensor has continuity. In the control panel the bake relay clicks the same as the broiler relay. Any other tests or ideas would be great.
Check for continuity between the Bake terminals on the gas safety valve. Replace the dual gas safety valve if it's open. If there is nothing wrong then replace the control board (aka a clock). - The part number for the dual gas safety valve is AP4098213 - The part number for the control board is AP204793 Here are the break down diagrams for the Maytag range Model CRG9700BAWGene.
Hi Gene. I checked continuity and found the bake terminals open. I replaced the valve and the problem is solved. I was relieved as the valve was pricey and considered an electrical part, therefore non-returnable. Thank you very much for your help. mcbyrne,
You are welcome. I'm glad you were able to fix it.
