| » Oven Control ERC |
Model Number: RGJ534GEP2BG Brand: Hotpoint Age: More than 10 years
I ordered part #WB27T10327 from you and it came the other day. There was no wiring diagram with it, in order to hook it up. The old part I have does not have as many connections as the new part does. The old module has a 3 pin connector with 2 yellow wires, the new module has a 6 pin connector with; pin 1 (blue) pin 2 (orange) pin 3 (yellow) pin 4 & 6 (white) pin 5 (empty). I need to know, where do the 5 wires on the new module connect to? Can you email me a wiring diagram to show how the new module connects to the oven?
If you bought the part from Appliance Parts Pros, then call the customer service 877-477-7278, ask for Adam and he will help you.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I have a GE wall oven model JGRS14GEP1BG. I ordered part #WB27T10327 from you and it came the other day. There was no wiring diagram with it, in order to hook it up. The old part I have does not have as many connections as the new part does. The old module has a 3 pin connector with 2 yellow wires, the new module has a 6 pin connector with; pin 1 (blue) pin 2 (orange) pin 3 (yellow) pin 4 & 6 (white) pin 5 (empty). I need to know, where do the 5 wires on the new module connect to? Can you email me a wiring diagram to show how the new module connects to the oven?
Thank you |
Can you post a pictures of the old and the new control boards?
__________________
Thank you Gene for responding. I have taken multiple pictures so you can get a good look at what I have here.
Oven pictures by rnwcompany - Photobucket Thank You |
The black wire from the "L1" terminal on the old board goes to the "L1" terminal on the new board.
The white wire from "N" terminal on the old board goes to the "N" terminal on the new board. The green wire from the "GND" terminal on the old board goes to the "GND" terminal on the new board. The pink wire from the "BA" terminal on the old board goes to the "NO" relay terminal on the new board. You have to cut off the two yellow wires from the 3 pin old plug. These wires should be spliced with the two white wires (pin 4 & 6) from the plug supplied with the new board. All other wires from this plug should be insulated. Gene.
__________________
Gene,
We hooked up all the wires, turned the gas back on and tried to fire it up. It would not ignite. I do not need to light a pilot. It appears the ignitor switch is not working. In the box that I received the part in there was another black wire. Here is picture of the wire. Does it need to be plugged in somewhere? Maybe the relay? Does the relay need a common wire attached to it. On the new board there is nothing attached to the com connection on the relay. Does this relay need a common attached to it to work? piece pictures by rnwcompany - Photobucket Thank You |
Very likely this extra wire should connect the "L1" terminal with the "COM" relay terminal, but I would like to be sure about it. I spoke with the APP customer service and they should get more specific information from GE tomorrow.
__________________
Unfortunately there was not much help from GE. As far as I can recall from my memory this black wire should connect the "L1" & the "COM" terminals.
__________________
| Display Modes | |
| oven control | greg pezzolla | Oven Repair (including Ranges and Cooktops) | 3 | 01-21-2010 11:22 PM |
| GE Built-In Oven Control Panel - replace entire assembly or just control kit | boschuser | Oven Repair (including Ranges and Cooktops) | 1 | 01-05-2010 03:11 AM |
| Oven/clock Control Panel is no longer lit but oven does heat. | jthomas@abrakadoodle.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2009 04:07 PM |
| oven control | trask47 | Oven Repair (including Ranges and Cooktops) | 0 | 07-19-2008 09:52 AM |
| Ge Oven Control | jmajda12 | Oven Repair (including Ranges and Cooktops) | 1 | 08-15-2007 04:19 PM |
