Oven Temp seems to be off- I used to be a service tech years ago before the digital era. Then I could adjust the thermostat through the shaft of the control. Now it has to be done, I assume, from the board in the control panel. Any suggestions on where to look and if it is adjustable. Thanks in advance for any help. tagman
