My upper oven would not shut off and I would get an F2 error. Checked oven temp sensor and then replaced power relay board. Now upper oven will not even turn on and heat up. Everything else seems fine.
Could this be a defective hi limit thermostat? Is there some other reason the oven would not heat up? The display says heating and sits at 100F.
