Did the self clean. Inner glass (the one you can put your hand right on when you open the door) has been cracked for years but today when I self cleaned, I was wiping the glass and a piece about 1 inch by 1/2 inch broke out of the middle and fell down into the space between the two glasses. It's very thick but not quite 1/4 inch thick.
Can I use the oven at all with this little piece of glass missing? I have been using it for years with the crack in it but this is actually a little hole now.
What is the part number to replace it? Is it AP2125331 or #8 on the diagram? Also, can you tell me the link to step by step instructions for replacing the glass that is specific for this frigidaire self cleaning oven model #FEF353BFWE.
Thanks. I think I can do it myself as long as I have the right part to buy and the actual instructions for my frigidaire.
