| » Looking for used electronic control for ACS3350AS |
Model Number: ACS3350AS Brand: Amana Age: 5 - 10 years
Hi!
My Amana stove (ACS3350AS) has an electronic control unit that's on its way out. I would love to find a used one (they don't make them any longer), buy it from someone who would no longer use it (because it's broken). It does not need to be working, I'll use the parts to salvage mine. The part number is 31944801. Respond in this thread, or email me at ripngo at gmail dot com Thanks! Jeanl Ads By Google Related Models |
Well, I went ahead and filed a complaint with the BBB, given that Amana has been 100% un-helpful in this matter.
I would encourage anybody with the same issue to send a complaint to the BBB. My complaint number is 37028113 in case that's useful. Jeanl |
There are companies out there that fix obsolete appliance timers and controls.
Just do a Google. Since you are willing to buy a blown board I assume that you know what parts need replacing, have you tried just sourcing the parts?
__________________
Quote:
Hopefully someone will have an old board/housing for you.
If not you will have to do a jiggery pokery to hold the board in place. It is hard to be helpful here without actually being there as I am not sure what is moving. Perhaps you can epoxy it in, though epoxy often will not hold to plastic reliably so you may also have to install a couple screws for the epoxy to grab onto. Perhaps a couple zip ties. Perhaps a couple screws/bolts, problem here is trying to keep away from anything that could short out. In any case if you cannot get a new housing the unit is toast so you have nothing to loose giving it a shot.
__________________
Quote:
Jean |
Yes I have to agree with you that it is probably time for a new unit.
It sounds like this unit was not well designed and the area where the board is just heated up too much over the years.
__________________
Quote:
THe problem is, what's a reliable brand that will not cost $4000??? It's a bit depressing to see that spending over $1000 on a gas range does not guarantee that you'll be satisfied with your purchase... THanks for your help anyway! Jean |
| Display Modes | |
| Amana ACS3350AS Shuts off when hot | utahjeff | Oven Repair (including Ranges and Cooktops) | 14 | 01-07-2013 07:06 AM |
| Electronic Control Panel or Touch Pad Control Issue? | maxtout4u@aol.com | Dishwasher Repair | 0 | 10-08-2010 11:33 AM |
| Electronic Control | Chris Jordan | Dryer Repair | 0 | 06-10-2010 11:59 AM |
| No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board | hddman | Oven Repair (including Ranges and Cooktops) | 0 | 04-26-2010 12:09 PM |
| Electronic Control assembly | Cartographer | Dishwasher Repair | 2 | 10-28-2008 12:47 PM |
