Discuss
thermador stovetop ventilation
 in
My thermador gas stovetop has a downdraft fan. When you push a button at the back, a panel raises at
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » thermador stovetop ventilation
  #1 (permalink)
Old 11-23-2008, 12:23 PM
Junior Member
shuster is on a distinguished road
Default thermador stovetop ventilation
Brand: Thermador   Age: 1 - 5 years
My thermador gas stovetop has a downdraft fan. When you push a button at the back, a panel raises at behind the stovetop and you can then adjust the speed of the fan. The panel no longer raises when the button is pushed. I checked the voltage at the button and there is no voltage present. I checked the voltage at the terminal strip and it is good. There is a gear motor which is easy to acces and a gear motor switch which is a little harder to access. how can I check either the gear motor (windings?) or the switch. There is green corrosion on the GM switch connections but it is a small amount. If you could tell me how to check either one or what you suggest for troubleshooting, I would appreciate it. I have an electric meter to use for checking voltage or impedence.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Spacemaker 2.0 - New Ventilation Fan Won't Run tabroten Microwave Repair 3 02-23-2010 02:53 PM
Down draft Ventilation System estherk Heating, Ventilation, and Air Conditioning (HVAC) 0 12-14-2009 08:27 AM
thermador cook N ventilation does not work frankpark Oven Repair (including Ranges and Cooktops) 4 11-11-2009 09:27 AM
Downdraft ventilation mmrozek Heating, Ventilation, and Air Conditioning (HVAC) 0 04-15-2009 06:19 PM
CookTop Down Draft Ventilation DAF Heating, Ventilation, and Air Conditioning (HVAC) 0 12-08-2007 09:39 AM
