This Double Oven Was Installed In The Home New About 20 Years Ago. The Oven Works, However The Upper Left Hand Portion Of The Display Panel Does Not Light Up Or Work Ie. The Program Select/time Select Switch And The Clock. I Do Not Know If There Is A Fuse That Needs To Be Changed Or Some Other Part That Is Needed. I Was Informed That They No Longer Carry Parts For This Oven.
Originally Posted by: DEAN DAGGETT This Double Oven Was Installed In The Home New About 20 Years Ago. The Oven Works, However The Upper Left Hand Portion Of The Display Panel Does Not Light Up Or Work Ie. The Program Select/time Select Switch And The Clock. I Do Not Know If There Is A Fuse That Needs To Be Changed Or Some Other Part That Is Needed. I Was Informed That They No Longer Carry Parts For This Oven. Did you find out a solution? I'm having a similar problem.
