Discuss
Gas Odor in Oven
 in
I recently had to replace the wires coming off the oven control valve in the back of the range because
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Odor in Oven
  #1 (permalink)
Old 12-21-2010, 12:08 PM
Junior Member
seijojoe is on a distinguished road
Default Gas Odor in Oven
Model Number: CHG9800BAE   Brand: Maytag   Age: More than 10 years
I recently had to replace the wires coming off the oven control valve in the back of the range because we had a fire over Thanksgiving (my wife poked a hole in the aluminum pan containing the turkey). Everything works fine now, but there's a gas smell in the oven when the oven is off. Could the fire have damaged the oven control valve? As far as I can tell, all the gas connections up to the valve are not leaking. Joe
Related Models
Maytag CHG9800BAE RANGE- S/C S/I GAS
Maytag CHG9800BAM RANGE- S/C S/I GAS
Maytag CHG9830BAB RANGE- S/C S/I GAS
Maytag CHG9830BAE RANGE- S/C S/I GAS
Admiral CHGA400BAB RANGE- S/C S/I GAS
Admiral CHGA400BAE RANGE- S/C S/I GAS
Amana CHP105 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP105T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Whirlpool CHW8990XW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ1 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900WQ0 COMMERCIAL AUTOMATIC WASHER
Amana CI7.7 FREEZER- CHEST
Amana CI8.8 FREEZER- CHEST
Amana CI8.8-C FREEZER- CHEST
Amana CIC-3 REF - TOP MOUNT
Amana CIC-4H REF - TOP MOUNT
Amana CIC3 MISC / ACCESSORY
Amana CIC4 MISC / ACCESSORY
Amana CIC4H MISC / ACCESSORY
Amana CIC4K MISC / ACCESSORY
Maytag CIKHTM-1 MISC / ACCESSORY
Maytag CIKHTM-1V MISC / ACCESSORY
Amana CIM105 REF - BOTTOM MOUNTS
Amana CIM105L REF - BOTTOM MOUNTS
Amana CIM125 REF - BOTTOM MOUNTS
Amana CIM125L REF - BOTTOM MOUNTS
Amana CIM98 REF - BOTTOM MOUNTS
Amana CIM98L REF - BOTTOM MOUNTS
Amana CIMR-19 REF - SXS/I&W
Amana CIMR-22 REF - SXS/I&W
Hardwick CJ1616A49R RANGE- F/S STD GAS
Hardwick CJ1616W49R RANGE- F/S STD GAS
Hardwick CJ1626A49R RANGE- F/S STD GAS
Hardwick CJ1626W49R RANGE- F/S STD GAS
Thermador CJ302UB
Thermador CJ302US
Thermador CJ302UW
Thermador CJ302ZS
Hardwick CJ7121809RC WALLOVEN- STD GAS
Hardwick CJ7122809RC WALLOVEN- STD GAS
Hardwick CJ7141809RC WALLOVEN- STD GAS
Hardwick CJ7141819DE WALLOVEN- STD GAS
Hardwick CJ7142809RC WALLOVEN- STD GAS
Hardwick CJ9641A590R RANGE- F/S STD GAS
Hardwick CJ9641W590R RANGE- F/S STD GAS
Amana CJW1008.A COMMERCIAL MICROWAVES
Amana CJW1008.B COMMERCIAL MICROWAVES
Amana CJW1008.Z COMMERCIAL MICROWAVES
Amana CJW1040.A COMMERCIAL MICROWAVES
Amana CJW1040.B COMMERCIAL MICROWAVES
Amana CJW1040.Z COMMERCIAL MICROWAVES
Gaggenau CK062-604
Gaggenau CK064-604
Gaggenau CK066-604
Gaggenau CK067-604
Gaggenau CK069-604
Gaggenau CK074-604
Gaggenau CK074-614
Gaggenau CK074-624
Gaggenau CK163-604
Gaggenau CK169-604
Gaggenau CK260-604
Gaggenau CK270-604
Maytag CK277SS-1 MISC / ACCESSORY
Maytag CK277SS-1V MISC / ACCESSORY
Gaggenau CK390-615
Gaggenau CK394-615
Gaggenau CK396-615
Gaggenau CK590-615
Gaggenau CK596-615
Hardwick CKD7121810AC WALLOVEN- CONT CLEAN GAS
Hardwick CKD7122810AC WALLOVEN- STD GAS
Hardwick CKD7221819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7221819AC WALLOVEN- STD GAS
Hardwick CKD7222810AC WALLOVEN- STD GAS
Hardwick CKD7222819A WALLOVEN- STD GAS
Hardwick CKD7224810AC WALLOVEN- STD GAS
Hardwick CKD7224819A WALLOVEN- STD GAS
Hardwick CKD7241819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7242819A WALLOVEN- STD GAS
Hardwick CKD7244819A WALLOVEN- STD GAS
Hardwick CKD9512W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9516W421R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9517W429R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W79R RANGE- F/S STD GAS
Hardwick CKF9621K-560RQ GAS RANGE
Hardwick CKG4612MA539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4612MW539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MA639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MW639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG8421MA729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG8421MW729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG9622W439RGB RANGE-F/S CONT CLEAN GAS
Hardwick CKG9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A589RGD RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGD RANGE-F/S CONT CLEAN GAS
Amana CKS3020LL SURFACE UNIT- GAS
Amana CKS3020WW SURFACE UNIT- GAS
Amana CKU-617 RANGE- S/C S/I DDRAFT GAS
Amana CKU-617A RANGE- S/C S/I DDRAFT GAS
Frigidaire CL16CA1
Frigidaire CL16CA2
  #2 (permalink)
Old 12-21-2010, 12:15 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
You really oughta have that checked by a pro. Gas is something you don't want to mess with.
  #3 (permalink)
Old 12-21-2010, 12:24 PM
Junior Member
Default
Quote:
I've already sunk about $500 into this old stove, including two different repair companies that incorrectly diagnosed an earlier problem and installed parts unnecessarily. All I'm looking for here is an answer to whether or not the oven control valve is susceptible to heat (i.e. fire damage). Do you know anyone who is an expert in this area? Joe
  #4 (permalink)
Old 12-21-2010, 12:32 PM
Senior Expert
APP Volunteer
Default
The gas lines are aluminum. The only knowledge of the extent of the fire you had is by your desription. The valves themselves probably weren't damaged, but the connections and the lines need to be leak tested.
  #5 (permalink)
Old 12-21-2010, 12:50 PM
Junior Member
Default
Thanks. I'll go back and double check all the connections. Joe
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
RCA Bad odor carlbaughman Refrigerator & Freezer Repair 0 07-27-2009 08:43 AM
exhast fume odor from oven and stove snivoks Oven Repair (including Ranges and Cooktops) 0 12-07-2008 10:26 AM
Range/Oven Gas Odor Casey Donlon Oven Repair (including Ranges and Cooktops) 1 11-20-2007 05:35 PM
Range/Oven Gas Odor Casey Donlon Oven Repair (including Ranges and Cooktops) 1 11-20-2007 05:34 PM
Range/Oven Gas Odor Casey Donlon Oven Repair (including Ranges and Cooktops) 1 11-20-2007 05:32 PM
