Discuss
Kenmore bake element
 in
Hi! I have an old Kenmore oven/range. The bake element has broken---literally broken apart. I can't find the model number
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore bake element
  #1 (permalink)
Old 12-21-2010, 08:35 AM
Junior Member
Blakes7 is on a distinguished road
Default Kenmore bake element
Brand: Kenmore   Age: More than 10 years
Hi! I have an old Kenmore oven/range. The bake element has broken---literally broken apart. I can't find the model number anywhere. I've checked on the door, in the oven, under the range top, and in the drawer underneath. The only sticker is a warning sticker, but there are no numbers on it, except at the very bottom---PLT083-2. I've looked up bake elements on the web, and at this url is a matching one: http://www.************************....ove-Oven-Parts. It's the third one down. Would this one work, or is the voltage and wattage going to cause a problem? I don't want to blow up the house, or the oven, and I don't want to pay for a repairman for a simple repair. Any and all responses will be greatly appreciated. Thanks.
Ads By Google
  #2 (permalink)
Old 12-21-2010, 08:40 AM
Junior Member
Default
Hi, again. I noticed the url didn't post, so the web site was ************************. com. Thanks.
  #3 (permalink)
Old 12-21-2010, 10:43 AM
Junior Member
Default
Hi! I've found the model number. It's---911.9344190. The serial number is---4R227800. Thanks.
  #4 (permalink)
Old 12-21-2010, 12:52 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
This should be the correct element
Part number: AP2030968
Click on the picture for more info.
Remove power from the unit.
This is very important as many stoves still have 120 volts at the element even with the oven turned off.
Undo the screw holding the element to the back of the oven.
Gently pull the element into the oven.
Remove the wires/connectors from the element.
It is a good idea to clip something to the wires (Clothespin etc.) so they do not disappear into the back of the oven before you get the new element installed.
__________________
  #5 (permalink)
Old 12-22-2010, 09:13 AM
Junior Member
Default
Thanks for the response. I'll order the part today. Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Electric Range: No Heat From Bake Or Broil Element john7 Oven Repair (including Ranges and Cooktops) 5 11-30-2012 03:35 AM
Kenmore bake element stays on mtrammell Oven Repair (including Ranges and Cooktops) 3 01-29-2010 03:28 AM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
Kenmore range - oven's bake element stays on nauran99 Oven Repair (including Ranges and Cooktops) 5 04-24-2009 09:16 AM
Bake Element and BAKE cycle not working jeffman Oven Repair (including Ranges and Cooktops) 1 08-04-2007 10:18 PM
