Discuss
Incorrect oven temperature
 in
The oven temperature is real low. Both elements appear to be working.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Incorrect oven temperature
  #1 (permalink)
Old 12-20-2010, 06:34 AM
Junior Member
cpkennedy is on a distinguished road
Default Incorrect oven temperature
Brand: Whirlpool   Age: More than 10 years
  #2 (permalink)
Old 12-20-2010, 07:11 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Could be your oven sensor.
Here is a link with info on how to check it
http://www.applianceaid.com/elecrange.html
Also depends what you mean by "real low".
You can usually adjust the temperature plus or minus 35 degrees. See your operators manual.
__________________
  #3 (permalink)
Old 12-20-2010, 07:34 AM
Junior Member
NOTTI is on a distinguished road
Default
Quote:
MY ADVICE IS TO CHECK THE OVEN THERMOSTAT WITH A TEST METER
  #4 (permalink)
Old 12-20-2010, 11:38 AM
Junior Member
Default
I mean REAL low. It's like the thermostat is not properly operating. Is that hard to replace?
  #5 (permalink)
Old 12-20-2010, 11:40 AM
Junior Member
Default
It's REAL low. It's as if the thermostat is not working either properly or at all. is that hard to replace?
  #6 (permalink)
Old 12-20-2010, 11:46 AM
Junior Member
Default
NO ITS QUITE SIMPLE DISCONNECT FROM MAINS LOCATE THERMOSTAT (BEHIND KNOB AND ALSO SENSOR (INSIDE OVEN A LONG COPPER TUBE WITH WIRE GOING TO STAT) MAKE NOTES OF WIRE LOCATION (USUALLY TWO) THEN REPLACE IF IT IS A GAS OVEN THEN WONT BE ANY WIRES.
  #7 (permalink)
Old 12-20-2010, 01:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to provide most accurate advice we need the complete model number of the oven.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Incorrect oven temperature cwren Oven Repair (including Ranges and Cooktops) 2 06-06-2008 12:41 PM
