chuckc
#1 Posted : Saturday, November 22, 2008 9:37:54 AM(UTC)
chuckc
Getting error code F-3 when trying to use oven, convection fan runs continuosly heat sensor appears to ohlm out good, have replaced Relay board with no change. what should I try now??? main board??
libertyappl
#2 Posted : Saturday, November 22, 2008 9:54:16 AM(UTC)
libertyappl
Check the wiring to the sensor....
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nat
