| » replacing bake element |
Model Number: RB747G J7 Brand: Hotpoint Age: More than 10 years
The bake element is out on my oven. I am trying to find out if this is something that I can replace myself. I also need to find out the part number and where to get it.
First, make sure to disconnect power to the oven by turning off correct circuit breakers. This is very important. Do not replace the element if the oven is still getting power. It gets easier from here. The bake element is screwed on to the back wall with two screws. In addition, there are two wires connected to the element terminals behind the element mounting bracket. Remove both screws and pull slowly on the element. You should only be able to pull it out about 2 inches or so. Remove the wires from the element - be careful not to lose the wires behind the wall. Connect the wires to the new element and secure the new element with both screws. That's about it. Use the link below to order a new element.
- Replacement bake element for your Hotpoint oven. - Breakdown diagram for Model RB747G*J7 Hope this helps. |
| Display Modes | |
| Replacing a glass top burner element | billy_mc | Oven Repair (including Ranges and Cooktops) | 1 | 06-15-2008 09:11 PM |
| element heats up on broil but not on bake | RICO | Oven Repair (including Ranges and Cooktops) | 1 | 09-18-2007 08:24 PM |
| Bake Element Installation | HelpMeHelpMe | Oven Repair (including Ranges and Cooktops) | 2 | 08-20-2007 04:00 PM |
| Bake Element and BAKE cycle not working | jeffman | Oven Repair (including Ranges and Cooktops) | 1 | 08-04-2007 11:18 PM |
| Oven Will Not Bake | tony | Oven Repair (including Ranges and Cooktops) | 6 | 08-01-2007 06:21 PM |
