Whirpool fault code is: F2 E3 Replacement keypad is: 4451333, (not available). It was suggested to me by SEARS to buy similar part 8300454 ,..."it will fit". I have received it.... But it does Not fit because jumper film cable has 14 leads instead of 13 how many the old cable&conector has. How can I rewire it to make it work, even if I have to Loose some function of the oven??? Thank you, Milovan Nikolich
