Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Part number for Maytag oven control panel? (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/15171-part-number-maytag-oven-control-panel.html)
citulsja 11-20-2008 09:05 AM
Hi there, I have a two-year old Maytag MEW5530DDW oven, and it seems like random buttons on the control panel have failed (i.e. pressing on "bake", "broil" and "oven light" does nothing - yet somehow I get a response for "keep warm", "clean", etc...). I was told (granted, over the phone) by a repairman that I needed a new control panel, and he quoted me a price of CAD$265 (~US$210) for the panel, plus labour. Has anyone else had this problem? If indeed my only option is to replace the controller, can anyone suggest a place to order it from that would be cheaper?? Thanks!!
libertyappl 11-20-2008 11:17 AM
Here's a parts breakdown much like your unit although not the exact same model number ttp://www.appliancepartspros.com/partsearch/model.aspx?model_id=46828
The part number for the control board is AP3467952 (Control, h1 (clock/n)
from this site
The keypad is part number AP3464230 (Panel, control (wht))
I would check the keypad itself first. But if needed you can get both parts from here for a little more than he stated for replacing the control board.
Nat
Scott76723 10-02-2009 03:17 PM
mew5530ddw maytag..control panel not working
Have the control panel not working, some of the buttons function,but still not operational..
Trying to decide if its the keypad control or the board itself? Any ideas?
thanks, Scott
Gene 10-02-2009 08:02 PM
Scott,
Open the control panel, remove the control panel ribbon cable from the control board and check the tracks in the ribbon cable for a hairline cracks. A magnifying glass might help.
More likely the problem is a bad control panel, but there is a small chance for the control board to be bad as well.
- The control board Part number: AP4097369
- The control panel Part number: AP4424899
Here are the breakdown diagrams and Replacement parts for MAYTAG MEW5530DDW | AppliancePartsPros.com
wlmoseley 06-03-2010 09:30 PM
What solution did you arrive at?
