Discuss
Pf Code Will Not Reset
 in
My oven does not work, the clock & cooktop does. I am getting a steady PF code that will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Pf Code Will Not Reset
  #1 (permalink)
Old 12-12-2010, 09:31 AM
Junior Member
tleslie is on a distinguished road
Default Pf Code Will Not Reset
Model Number: GY398LXPB00   Brand: Whirlpool   Age: 1 - 5 years
My oven does not work, the clock & cooktop does. I am getting a steady PF code that will not clear, & touchpad does not respond at all. My incoming power checks 220 / 110 at receptacle. I have replaced the control and the touchpad, so I am way past the point of no return. Any help at this point would be much appreciated.
Thanks,
Ads By Google
Related Models
Whirlpool GY398LXPB00 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPB01 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPB02 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPB03 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPB04 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPQ00 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPQ01 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPQ02 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPQ03 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPQ04 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPS00 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPS01 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPS02 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPS03 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPS04 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPT00 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPT01 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY398LXPT02 30" Slide-In ELECTRIC OVEN SELF CLEAN
Whirlpool GY399LXUB0 30" SLIDE-IN ELECTRIC RANGE
Whirlpool GY399LXUB02 30" SLIDE-IN ELECTRIC RANGE
Whirlpool GY399LXUB04 30" Slide-In Electric Range
Whirlpool GY399LXUQ0 30" SLIDE-IN ELECTRIC RANGE
Whirlpool GY399LXUQ04 30" Slide-In Electric Range
Whirlpool GY399LXUS0 30" SLIDE-IN ELECTRIC RANGE
Whirlpool GY399LXUS02 30" SLIDE-IN ELECTRIC RANGE
Whirlpool GY399LXUS04 30" Slide-In Electric Range
Whirlpool GY399LXUT0 30" SLIDE-IN ELECTRIC RANGE
KitchenAid GZ25FDRXYY0 REFRIGERATOR
KitchenAid GZ25FSRXYY0 REFRIGERATOR
Admiral GZ2626GEKB REF - SXS/I&W
Whirlpool GZ2626GEKB13 REFRIGERATOR
Admiral GZ2626GEKS REF - SXS/I&W
Whirlpool GZ2626GEKS13 REFRIGERATOR
Admiral GZ2626GEKW REF - SXS/I&W
Whirlpool GZ2626GEKW13 REFRIGERATOR
Admiral GZ2727GEHB REF - SXS/I&W
Admiral GZ2727GEHQ REF - SXS/I&W
Admiral GZ2727GEHW REF - SXS/I&W
Whirlpool GZ5730XLB0 RANGE HOOD
Whirlpool GZ5730XLQ0 RANGE HOOD
Whirlpool GZ5730XLS0 RANGE HOOD
Whirlpool GZ5730XLT0 RANGE HOOD
Whirlpool GZ5730XRB0 RANGE HOOD
Whirlpool GZ5730XRB1 RANGE HOOD
Whirlpool GZ5730XRQ0 RANGE HOOD
Whirlpool GZ5730XRQ1 RANGE HOOD
Whirlpool GZ5730XRS0 RANGE HOOD
Whirlpool GZ5730XRS1 RANGE HOOD
Whirlpool GZ5730XRT0 RANGE HOOD
Whirlpool GZ5730XRT1 RANGE HOOD
Whirlpool GZ5736XLB0 RANGE HOOD
Whirlpool GZ5736XLQ0 RANGE HOOD
Whirlpool GZ5736XLS0 RANGE HOOD
Whirlpool GZ5736XLT0 RANGE HOOD
Whirlpool GZ5736XRB0 RANGE HOOD
Whirlpool GZ5736XRB1 RANGE HOOD
Whirlpool GZ5736XRQ0 RANGE HOOD
Whirlpool GZ5736XRQ1 RANGE HOOD
Whirlpool GZ5736XRS0 RANGE HOOD
Whirlpool GZ5736XRS1 RANGE HOOD
Whirlpool GZ5736XRT0 RANGE HOOD
Whirlpool GZ5736XRT1 RANGE HOOD
Whirlpool GZ7730XGS0 RANGE HOOD
Whirlpool GZ7730XGS1 30" RANGE HOOD (Use with Gas or Electric Range)
Whirlpool GZ7736XGS0 RANGE HOOD
Whirlpool GZ7736XGS1 30" RANGE HOOD (Use with Gas or Electric Range)
Whirlpool GZ7930XGS0 RETRACTABLE DOWN DRAFT VENT SYSTEM
Whirlpool GZ7930XHS0 VENT SYSTEM
Whirlpool GZ7930XHS1 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM (INTERNAL VENTING)
Whirlpool GZ7936XGS0 RETRACTABLE DOWN DRAFT VENT SYSTEM
Whirlpool GZ7936XHS0 VENT SYSTEM
Whirlpool GZ7936XHS1 30" AND 36" RETRACTABLE DOWN DRAFT VENT SYSTEM (INTERNAL VENTING)
Whirlpool GZ8330XLS0 30" & 36" RANGE HOOD (Vented) (Use With Gas Or E
Whirlpool GZ8330XLS1 30" & 36" RANGE
Whirlpool GZ8336XLS0 30" & 36" RANGE HOOD (Vented) (Use With Gas Or E
Whirlpool GZ8336XLS1 30" & 36" RANGE
Bosch GZ900-060
Bosch GZ936-010
Whirlpool GZ9730SSS0 30" & 36" Hood
Whirlpool GZ9730XSS0 30" & 36" Hood
Whirlpool GZ9736SSS0 30" & 36" Hood
Whirlpool GZ9736XSS0 30" & 36" Hood
Bosch GZ990-010
Bosch GZ991-010
Bosch GZ992-010
Hardwick H-414 SURFACE UNIT- GAS
Hardwick H-434 SURFACE UNIT- GAS
Hardwick H-444 SURFACE UNIT- GAS
Hardwick H-445 SURFACE UNIT- ELE
Hardwick H-446 SURFACE UNIT- GAS
Thermador H-62 RANGE HOOD
Thermador H-62A RANGE HOOD
Thermador H-63 RANGE HOOD
Thermador H-63A RANGE HOOD
Thermador H-64 RANGE HOOD
Thermador H-65 RANGE HOOD
Thermador H-66 RANGE HOOD
Thermador H-66A RANGE HOOD
Thermador H-67 RANGE HOOD
Thermador H-67A RANGE HOOD
Thermador H-71 RANGE HOOD
Thermador H-76 RANGE HOOD
Thermador H-98 RANGE HOOD
Hoover H1005---
Hardwick H1100PAW RANGE- F/S STD GAS
Hardwick H1100PRA RANGE- F/S STD GAS
Hardwick H1100PRA-K RANGE- F/S STD GAS
Hardwick H1100PRW RANGE- F/S STD GAS
Hardwick H1100PRW-K RANGE- F/S STD GAS
Hardwick H1500PRW RANGE- F/S STD ELE
Frigidaire H15A Frg(v1) / Chest Freezer
Frigidaire H15B Frg(v2) / Chest Freezer
Frigidaire H15C Frg(v3) / Chest Freezer
Frigidaire H20A Frg(v1) / Chest Freezer
Frigidaire H20B Frg(v2) / Chest Freezer
Frigidaire H23A Frg(v1) / Chest Freezer
Frigidaire H23B Frg(v2) / Chest Freezer
Hoover H2510
Hoover H2800--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H2800050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
  #2 (permalink)
Old 12-13-2010, 09:22 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Thanks,
T,
What was the original problem ?
Failure codes etc. ?
The "PF" code indicates a power failure.
You have 220 VAC at the outlet, but,
Do you have 220 VAC at the terminal block ?
Do you have 110 VAC from L1 to Neutral, and L2 to Neutral at the terminal block.
What about 110 VAC at the clock connector ?
(Clock Connector P4, pin#1(white) to pin#3(black)with the connector attached and insert your meter probes through the back(wire insertion side),and the clock display on, you should read line voltage(110 VAC).
With the repairs you've made, I would have to think, you've got a voltage or wiring problem at or to the ERC/clock, when voltage is applied to it(under a load).
Let us know what you find,Please ...
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-13-2010, 06:38 PM
Junior Member
Question Pf Code Will Not Clear (reply)
The original problem started while the oven & cook top were in operation. The touchpad showed a code breifly and then went to all 8/s. I did not record the code, but shut off the power to the unit and then turned back on. The stove came up with the "PF" and that is the way it has stayed
throughout all the attemps to repair.
Tonight I tested the voltage at the range connections. I got 119 V at both L1 to N, & L2 to N, & 239 V at L1 to L2. I am getting 119 v at the clock connections under load as you instructed,
FYI, I did check the resistance thru the oven thermostat. I got "0" ohms. I checked with the leads still connected as was suggested by the manual I was using. Isn't that supose to be something like 1009 ohms at room temp? Could that be the problem?
The only other thing I did yesterday was was to jumper around the hi temp bi-metal switch, because I was getting high resistance thru it (leads removed). What would you suggest next?
Thanks,
Quote:
Originally Posted by Joe / APP Team View Post
T,
  #4 (permalink)
Old 12-14-2010, 06:40 AM
Senior Expert
Default
Thanks,
T,
Well,
Based on your resistance reading and the voltage readings you stated,
You have a bad oven Temp Sensor, You should read a resistance of 1050 to 1100 ohms across the wires at room temperature, you said you had 0 ohms .
Part number: AP4321511
I've never had a bad sensor cause a "PF" code, but it is a possibility.
Your voltage readings that you supplied, are in range and proper.
You may want to try this, to be positive there's no problem.
With 2 or 3, top burners, on re check your voltage at the terminal block of the range,
Check L1 to Neutral , then L2 to neutral, You may loose a volt or two, but there should not be a major voltage differrence.
Your thermal cut out is OK.
Otherwise, the only thing I see that you need is the oven temp sensor.
And check to make sure you've got the key pad ribbon installed properly at the clock connection.
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 12-16-2010, 09:43 AM
Junior Member
Default Pf Code Will Not Clear
In my previous request, I mistakenly told you that my oven temperature sensor (part#W10131825) was reading a resistance of "0" ohms. Instead, what I actually tested was over temp sensor (Part #4451442). I am guessing that is suppose to be "0" ohms. Is that right? If so, I am back to square one, with a W10131825 part I probably don't need. Do you have any other suggestions?
Thanks,
  #6 (permalink)
Old 12-16-2010, 11:48 AM
Senior Expert
Default
Thanks,
T,
On your over temp sensor you should read infinite resistance(000) or CL on some digital meters.
Even so, that still should not cause a "PF" code, it will not allow the oven to heat.
You could try this,
Take both wires off the over temp sensor and attach them together, and insulate them so they can't short out, then program the clock and see if you can program a bake cycle.
At the same time, check the voltage at the clock power supply(per the previous post). the circuit in that clock can only handle a momentary 2 to 5 volt drop before it gives to "PF" code.
Let us know what you find, please, I'm running out of options and tests.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool / cant reset code 9xxx Oven Repair (including Ranges and Cooktops) 0 03-13-2010 04:54 PM
How To Reset goodhumormarc Refrigerator & Freezer Repair 0 01-04-2010 10:29 PM
No reset? sanantonio6355 Garbage Disposer Repair 2 08-20-2009 12:48 PM
won't HEAT is there a reset code? draleigh53 Microwave Repair 1 01-22-2009 12:26 PM
reset erasto12 Dishwasher Repair 8 09-04-2008 09:51 PM
