Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Can't remove bulb cover (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/150391-cant-remove-bulb-cover.html)
juliedealer 12-09-2010 11:35 AM
I cannot remove the bulb cover in the oven. It should twist off. But instead of the glass unscrewing the entire base turns. Is there something I can use to losen the two? Or can I go in from the back of the stove to solve the problem?
ApplianceJunk 12-09-2010 01:02 PM
You will have to get to the back of the oven to hold it from turning.
