Groups ready for retrieval: Registered
I recently ordered a replacement oven igniter for my Amana range. The igniter I received has a 5.25 inch ceramic base. The existing igniter has a 1.75 inch ceramic base. This is the manufacturers recommended replacement part, but is there room for the larger igniter on my stove? Do I need the smaller part? and if so, what is the correct part number.
Order # 1513183
Larry Pierce
LCPierce I recently ordered a replacement oven igniter for my Amana range. The igniter I received has a 5.25 inch ceramic base. The existing igniter has a 1.75 inch ceramic base. This is the manufacturers recommended replacement part, but is there room for the larger igniter on my stove? Do I need the smaller part? and if so, what is the correct part number. Order # 1513183 Larry Pierce Read more: http://forum.appliancepartspros...p;t=150360#ixzz17dba56ed http://forum.appliancepartspros.com
