Push bake and then baking temp and starts showing 100 then shuts off. Did start making a buzzing sound. Would this be in control panel? Burner on top work, but one which hasn't worked since we got it? Help before I have to get someone out here! Showed f1 code, and I did unplug and try gain, same results starts buzzing and just seems to shut off. Help
Sounds like the control board has gone bad.
We need more detailed description on the burner problem.
What is the complete model number of the range and the color of the key pad?
control panel is black. not sure of model #, booklet has 3 different #s JGBP31GEP, JGBP34GEP, JGBP35GEP. So sounds like we mys well start checking prices for a new stove. Probably parts and repairman could lots? Not sure about burner, never worked since we moved in, so I just don't use that one. Thanks.
Your decision about a new stove is right, especially because the control board for this range is no longer available.
Is it a easy fix to replace control panel? I just saw same make as mine listed on craigslist for $125, thought maybe I could get part or oven. What do ya think. Looks like were looking at well over $500 to start looking for a replacement, sucks with holidays soon! Also there used to be a huge parts place and I can't find it, they carry almost everything cause I used them years ago. Do you have any idea what I'm talking about? Thanks so much for listening to me BIT-- and for your help.
Originally Posted by: angmf2233 ...I just saw same make as mine listed on craigslist for $125, thought maybe I could get part or oven... You can try your luck because you don't know the condition of it and there are no returns. You also can try to rebuild the old control board. Try PCBR.BIZ It's almost impossible to find a part if it was discontinued by the manufacturer. Gene.
