Discuss
Caloric double oven/bottom oven doesn't heat
 in
I have a caloric double oven. Then bottom oven doesn't get hot, but it broils. I see the pilot light
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Caloric double oven/bottom oven doesn't heat
  #1 (permalink)
Old 11-17-2008, 06:10 PM
Junior Member
kj0505 is on a distinguished road
Default Caloric double oven/bottom oven doesn't heat
Brand: Caloric   Age: More than 10 years
I have a caloric double oven. Then bottom oven doesn't get hot, but it broils. I see the pilot light lit, and I smell gas. This happened before, when I cleaned it really well, it started working again. It quit again and I need it for my Turkey! My top oven gets too hot to bake in.
Ads By Google
  #2 (permalink)
Old 12-10-2008, 09:14 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a weak oven igniter which has to be replaced to solve it. In order to provide most accurate advise we need the complete model number of the range.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Double oven burner not working on bottom mirekjanowiak Oven Repair (including Ranges and Cooktops) 5 12-26-2009 03:38 PM
Old Caloric oven won't heat and I can't read the model number!!! jsm115 Oven Repair (including Ranges and Cooktops) 1 12-15-2008 05:32 PM
Frigidaire double oven twin error codes F23 top and bottom mitchfix1 Oven Repair (including Ranges and Cooktops) 3 12-01-2008 08:40 AM
Will Not Ignite ;caloric Double Oven Rwd 212 bobd1950 Oven Repair (including Ranges and Cooktops) 1 11-29-2008 07:52 PM
THERMADOR double oven no heat ialandmeier Oven Repair (including Ranges and Cooktops) 0 04-03-2008 10:06 AM
