I am having trouble with 2 of my burners. The 8" burner likes to go red hot when it is turned on, no matter the setting (you can hear a small click occasionally when you turn it on). The 6" burner directly across from it on the right front does pretty much the opposite. It stays lukewarm (actually touchable) unless you turn the burner on to a "6" or higher setting.
We are guessing we need new control switches, knobs, or something similar. Please help.
Thank you in advance.
THIS FORUM IS DEAD!!!!!!! |
