:mad: My oven stopped heating. I was using the oven at 200 degrees and after about 2 hours it stopped heating. I turned it off and turned it back on at a higher temperture, 350 degrees. It did not go on. The top burners all work and so does the clock. What should I do?
Originally Posted by: Francisco Dan :mad: My oven stopped heating. I was using the oven at 200 degrees and after about 2 hours it stopped heating. I turned it off and turned it back on at a higher temperture, 350 degrees. It did not go on. The top burners all work and so does the clock. What should I do?
