Washer will not drain and spin we have cleaned all hoses and pump of any debris. I ran a continuity test on the windings for the pump and they are not open. I would like to know if there is anything else I can check before calling a repairman to come and look at the thing. The only thing I can add is that this has been building slowly and may be related to some sort on control problem. Is there a reset button or some way to clear errors that may be building up in the control board.
