it started with the oven shutting off before reaching desired temperature. after trying again, the oven temperature kept climbing, and the alarm went off with an f 2 error. After I changed the oven sensor, there is no alarm or f2 error, but the oven still shut's off before getting to temp. What should I do?;) :confused:
