Discuss
Jenn-Air wall oven
 in
The control panel (clock) stopped working, therer was a buzzing noise behind control panel. I removed cover and found the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air wall oven
  #1 (permalink)
Old 11-16-2008, 05:25 PM
Junior Member
Brian Breazeale is on a distinguished road
Default Jenn-Air wall oven
Model Number: w30100w   Brand: Jenn-Air   Age: 5 - 10 years
I removed cover and found the relay board (controls the fan and the door lock) buzzing. I replaced the main control board. oven works but fan did not. After further checks found fan motor coils open, burnt and found that the relay board was not suppling voltage to the fan. At this point i am planning an replacing the relay board and the fan motor. any ideas what caused these problems??
Note: the door lock portion of the relay board works.
Thanks Brian
Ads By Google
Related Models
Jenn-Air W30100W Walloven - S/c Ele
Jenn-Air W30100WC Walloven - S/c Ele
Jenn-Air W30400B Walloven - S/c Ele
Jenn-Air W30400BC Walloven - S/c Ele
Jenn-Air W30400P Walloven - S/c Ele
Jenn-Air W30400PC Walloven - S/c Ele
Jenn-Air W30400PF Walloven - S/c Ele
Jenn-Air W30400PG Walloven - S/c Ele
Jenn-Air W30400PK Walloven - S/c Ele
Jenn-Air W30400PR Walloven - S/c Ele
Jenn-Air W30400PU Walloven - S/c Ele
Jenn-Air W30400W Walloven - S/c Ele
Jenn-Air W30400WC Walloven - S/c Ele
Frigidaire WA24F4DTFB Gib(v4) / Top Load Washer
Frigidaire WA24F4WTFA Gib(v2) / Automatic Washer
Frigidaire WA24F4WTFB Gib(v3) / Top Load Washer
Frigidaire WA24P2DTFB Gib(v2) / Top Load Washer
Frigidaire WA24P2DVFA Gib(v2) / Top Load Washer
Frigidaire WA24P2WSFA Gib(v1)
Frigidaire WA24P2WSFB Gib(v2)
Frigidaire WA24P2WTFA Gib(v1) / Automatic Washer
Frigidaire WA24P2WTFB Gib(v1) / Top Load Washer
Frigidaire WA24P2WVFA Gib(v1) / Top Load Washer
Frigidaire WA24P2WVMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMA Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMC Gib(v1) / 24 " Washer
Frigidaire WA27F2WAFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WAFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F4WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M4WAFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WAFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WXFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M4WXFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27M6WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M6WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M8WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M8WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27S1WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA28D3WSFA Gib(v3)
Frigidaire WA28D4WSFA Gib(v4)
Frigidaire WA28D4WTFA Gib(v1) / Automatic Washer
Frigidaire WA28D5WSFA Gib(v5)
Frigidaire WA28D7WSFA Gib(v6)
Frigidaire WA28F2DTFB Gib(v5) / Top Load Washer
Frigidaire WA28F2WTFA Gib(v5) / Automatic Washer
Frigidaire WA28F2WTFB Gib(v1) / Top Load Washer
Frigidaire WA28F2WTFC Gib(v1) / Top Load Washer
Frigidaire WA28M2DTFB Gib(v6) / Top Load Washer
Frigidaire WA28M2WTFA Gib(v4) / Automatic Washer
Frigidaire WA28M2WTFB Gib(v2) / Top Load Washer
Frigidaire WA28M2WTFC Gib(v2) / Top Load Washer
Frigidaire WA28M4DTFB Gib(v7) / Top Load Washer
Frigidaire WA28M4WTFA Gib(v3) / Automatic Washer
Frigidaire WA28M4WTFB Gib(v3) / Top Load Washer
Frigidaire WA28M4WTFC Gib(v3) / Top Load Washer
Frigidaire WA28M4YTFB Gib(v9) / Top Load Washer
Frigidaire WA28M6DTFB Gib(v8) / Top Load Washer
Frigidaire WA28M6WTFA Gib(v2) / Automatic Washer
Frigidaire WA28M6WTFB Gib(v4) / Top Load Washer
Frigidaire WA28M6WTFC Gib(v4) / Top Load Washer
Frigidaire WA28S2WSFA Gib(v7)
Frigidaire WA3900AWL1 Frg(v4) / 27 " Washer
Frigidaire WA3900AWL2 Frg(v4) / 27 " Washer
Frigidaire WA3900AWW1 Frg(v3) / 27 " Washer
Frigidaire WA3900AWW2 Frg(v3) / 27 " Washer
Frigidaire WA3900AWW3 Frg(v1) / 27 " Washer
Frigidaire WA4720RW1 Frg(v1) / 27 " Washer
Frigidaire WA4720RW2 Frg(v1) / 27 " Washer
Frigidaire WA4900ADD1 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD2 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD3 Frg(v2) / 27 " Washer
Frigidaire WA4900AWW1 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW2 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW3 Frg(v3) / 27 " Washer
Frigidaire WA4900RW1 Frg(v1) / 27 " Washer
Frigidaire WA5800ADD1 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD2 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD3 Frg(v1) / 27 " Washer
Frigidaire WA5800AWW1 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW2 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW3 Frg(v2) / 27 " Washer
Frigidaire WA5800RW1 Frg(v2) / 27 " Washer
Frigidaire WA5820RW1 Frg(v1) / 27 " Washer
Frigidaire WA5820RW2 Frg(v1) / 27 " Washer
Frigidaire WA6500ADD1 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD2 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD3 Frg(v3) / 27 " Washer
Frigidaire WA6500AWW1 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW2 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW3 Frg(v4) / 27 " Washer
Frigidaire WA6520AL1 Frg(v2) / 27 " Washer
Frigidaire WA6520AL2 Frg(v2) / 27 " Washer
Frigidaire WA6520AW1 Frg(v1) / 27 " Washer
Frigidaire WA6520AW2 Frg(v1) / 27 " Washer
Frigidaire WA6620RW1 Frg(v1) / 27 " Washer
Frigidaire WA6620RW2 Frg(v1) / 27 " Washer
Frigidaire WA6900RW1 Frg(v3) / 27 " Washer
Frigidaire WA7200ADD1 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD2 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD3 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW1 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW2 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW3 Frg(v2) / 27 " Washer
Frigidaire WA7400PW0 Frg(v1) / 27 " Washer
Frigidaire WA7400PW1 Frg(v1) / 27 " Washer
Frigidaire WA7400PW2 Frg(v2) / 27 " Washer
Frigidaire WA8600PW0 Frg(v1) / 27 " Washer
Frigidaire WA8600PW1 Frg(v1) / 27 " Washer
Frigidaire WA8600PW2 Frg(v2) / 27 " Washer
Frigidaire WA8800PW0 Frg(v1) / 27 " Washer
Frigidaire WA8800PW1 Frg(v1) / 27 " Washer
  #2 (permalink)
Old 11-17-2008, 02:31 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Your motor probably shorted while burning out, causing the relay to burn out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Wall Oven display tyke58 Oven Repair (including Ranges and Cooktops) 22 09-04-2012 12:54 AM
Jenn-Air wall oven Mike Hallada Oven Repair (including Ranges and Cooktops) 1 10-03-2009 01:19 PM
Jenn-air wall oven dem1969l@fast.net Oven Repair (including Ranges and Cooktops) 0 08-27-2009 10:14 AM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
Jenn air wall oven LesleyFarm Forum Announcements 0 08-01-2008 03:38 PM
