right front ignitor wont click when you turn it on. all others work fine. ideas what it could be?
Most likely the problem is a bad ignition switch. You have to replace the whole switch harness (#323 on the break down diagram) because they do not come separate. Here are the break down diagrams for the GE stove Model JGP328WEC1WWGene.
