| » jenn-air oven problems |
Model Number: sve47600b Brand: Jenn-Air Age: 5 - 10 years
I had a fault code of F-5 and replaced the electronic control assembly and the oven still does not heat up at all.I also replace the temp sensor in oven and the heating elements check out ok.The F-5 code states a power to element relays disabled in cook mode and components to check are intermittent sensor or wire connection or intermittent contact on PRB.I still have not figured out why it is not working.Any suggestions ?
| Display Modes | |
| Jenn Air stove key pad problems | sefalk | Oven Repair (including Ranges and Cooktops) | 4 | 01-14-2012 01:09 PM |
| Jenn air oven problems | patrickC | Oven Repair (including Ranges and Cooktops) | 1 | 08-17-2010 04:30 PM |
| Jenn Air, two problems with oven | flopsy | Oven Repair (including Ranges and Cooktops) | 3 | 06-30-2009 02:58 PM |
| Problems with Jenn-Air SCE30600w | ogredive | Oven Repair (including Ranges and Cooktops) | 1 | 04-15-2009 03:27 PM |
| preheat problems w/ jenn air | cristin66 | Oven Repair (including Ranges and Cooktops) | 0 | 12-16-2008 05:23 PM |
