Discuss
GE Double Oven Double F4
 in
* Edit * Oven model is GE JKP44GOP13G My GE double oven (electric) is beeping and displaying a code F4
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Double Oven Double F4
  #1 (permalink)
Old 12-01-2010, 07:28 AM
MRH MRH is offline
Junior Member
MRH is on a distinguished road
Question GE Double Oven Double F4
Brand: GE   Age: 5 - 10 years
My GE double oven (electric) is beeping and displaying a code F4 whenever I try to use either the top or bottom. Initially the code only came up when I used the bottom, then the problem started with the top.
In order to stop the beeping I had to shut off power to the oven to stop the beeping, that's when I noticed resetting the power got the top working again but eventually resetting did not help.
I thought at first that I had a bad temp sensor, but now with both ovens not working I think this may be a circuit or wiring problem, anyhow I pulled the control panel and didn't see any signs of trouble.
Any suggestions?
Thanks for the help.
Ads By Google
  #2 (permalink)
Old 12-01-2010, 08:01 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Any suggestions?
MRH,
Unfortunately, you didn't supply a model number for your unit.
We can give you some basic, general information, at this point.
Most control boards will display failure codes, it does not always specify which specific oven has the failure. Some of the newer, more elaborate controls do.
A lot of the control boards, after displaying a fail code for a certain amount of time or displays, will eventually, shut the whole system down, even if there is only one disabled component.
We can be more exact and precise with a proper model and serial number, and can answer your inquiries properly.
Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-02-2010, 12:33 PM
MRH MRH is offline
Junior Member
Default
The oven model is GE JKP44GOP13G
Thanks for the assistance.
  #4 (permalink)
Old 12-03-2010, 10:02 AM
Senior Expert
Default
MRH,
Well, Let's start with the obvious and easy stuff.
You have a F4 fail code ( oven sensor shorted ).
Do you have a multi meter, so you can check the oven sensor(s) resistance ?
You can remove the sensor from inside the oven cavity, just don't loose the wires.
With a meter, check across the two wires on the sensor for 1100 ohms or less(1084 ohms average) at room temperature.
Boil water (212 degrees), insert sensor into boiling water(don't touch the sides or bottom of the pot) and the resistance should increase to approximately 1350 ohms.
Test both sensors, if there is a more that 50 ohm resistance difference than I've stated, you'll need a new sensor.
From there, if all checks OK,we will have to check the resistance at the control board connections with the sensor(s) re installed, we don't want to have to pull the oven out of the cabinet, if we don't need to.
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 12-03-2010, 02:24 PM
MRH MRH is offline
Junior Member
Default
Thanks for the help, I'll have to borrow or buy a multimeter but I'm glad to hear I don't have to pull the oven out of the wall. I'll post what I find.
  #6 (permalink)
Old 12-03-2010, 02:43 PM
Senior Expert
Default
MHR,
Here's the part number for the meter I would reccomend
Part number: AP3873826
It's pretty flexible and could come in handy around the house, car etc.
But if you can borrow, or purchase another meter, even better.
Will be looking for your update, in the near future.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
double oven dsergent@hemc.net Oven Repair (including Ranges and Cooktops) 1 07-04-2009 01:28 PM
Double GE Oven ginger@telfairbrokers.com Oven Repair (including Ranges and Cooktops) 0 11-25-2008 04:43 PM
Double Oven DirkSamuelson Oven Repair (including Ranges and Cooktops) 1 11-25-2008 01:04 PM
GE double oven NEED HELP! davetalife Oven Repair (including Ranges and Cooktops) 1 11-20-2008 04:24 PM
GE double oven jim heffington Oven Repair (including Ranges and Cooktops) 1 11-29-2007 08:05 PM
