I have failure code F1 intermittant from up to 4 days to constant
I have replaced the ERC controller & main relay board. I get 0 volts on J2 pins 1&3 with error code F1 not lit & -24 volts with error code F1 lit. I removed small connector from control panel to main relay board & still got error code F1 :cool:
