Hi: The DLB relay keeps failing. Replaced it once, lasted several months. Replaced again lasted a few weeks. Replaced clock / touch pad control board and relay and relay lasted a few days. Appliance repair tech came out and replaced the relay and a wire (not sure which wire or why) but it only lasted one use. The clock display flashes (no codes) and that is how we know the problem is back. The tech said if it happens again he may have to replace the oven elements. Does that make sense?
