When first turning on oven it works fine until it hits temp and the Preheated light comes on and never goes off. When oven burner tries to relight the ignitor glows and burner lights for a second or two and then shuts off. If we shut off oven dial and then turn back on the oven seems to work okay (burners light and stay on) until the the Preheated light comes on and causes problem again.
My rgb745bea6wh is doing the excact same thing. Need Help!
