I've had numerous issues with the control board on this particular double oven. The control board has been replaced 2 times in the past and I just noticed that the display is out once again.
The light on the inside of the oven works and the display beeps. The oven will not start at all.
I was away from home when this issue occurred (this is a second home).
Does this issue sound like the control board once again?
Additionally, it appears that the control panel for my oven is on backorder or no longer available?
Any help that you can provide would be greatly appreciated.
