Discuss
dacor double wall oven lite inop
 in
for some reason, my dacor double wall ovens wont illuminate ( inside the oven ) when the lite buttons on the panel
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » dacor double wall oven lite inop
  #1 (permalink)
Old 11-13-2008, 07:38 PM
cfilice cfilice is offline
Junior Member
cfilice is on a distinguished road
Default dacor double wall oven lite inop
Brand: Dacor   Age: 1 - 5 years
for some reason, my dacor double wall ovens wont illuminate ( inside the oven ) when the lite buttons on the panel are pushed ( there are two buttons, one for upper oven and one for lower ). Any ideas would be appreciated.
  #2 (permalink)
Old 11-13-2008, 09:08 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
The first thing I would check are the light bulbs.
__________________
  #3 (permalink)
Old 11-14-2008, 08:35 AM
Junior Member
Gene, I will check the bulbs. But, since they both failed at the same time, it seems unlikely. Is there anything that could cause both lite switches to fail at the same time ( something in the control panel )?
  #4 (permalink)
Old 11-14-2008, 01:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Lets do one thing at a time. Check the light bulbs first.
Is there push in switch on the door frame or just the pad on the control panel? What is the complete model number of the oven?
__________________
  #5 (permalink)
Old 11-18-2008, 11:09 AM
Junior Member
Default
Gene, no buttons on the door. The model number is MCS 227S.
  #6 (permalink)
Old 11-18-2008, 11:12 AM
Junior Member
Default
Gene, also, I did check one of the bulbs ( there are four total, two in each oven ). The bulb was fine. There are two buttons on the control panel. One for the upper oven and one for the lower. Neither button causes anything to happen.
  #7 (permalink)
Old 11-18-2008, 11:47 AM
magician59 magician59 is offline
Senior Expert
APP Volunteer
magician59 is on a distinguished road
Default
Do you hear the faint click of a relay when you press a button, or no sound at all?
  #8 (permalink)
Old 11-18-2008, 12:36 PM
Junior Member
Default
No, absolutely no sound at all on either button.
  #9 (permalink)
Old 11-18-2008, 12:49 PM
Senior Expert
APP Volunteer
Default
I suspect a bad relay or control board.
  #10 (permalink)
Old 11-18-2008, 02:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the control panel and check the low voltage lights transformer. The lights in this oven are a halogen 10W 12V, so there suppose to be 12V at the secondary windings. Here are the wiring diagrams for this oven.
- The part number for the transformer is AP3391742
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Wall oven choldca Oven Repair (including Ranges and Cooktops) 6 10-13-2009 03:43 PM
Dacor wall oven - fails preheat ericrah Oven Repair (including Ranges and Cooktops) 1 10-04-2008 06:51 PM
Dacor double oven, lower oven failure tuckspub Oven Repair (including Ranges and Cooktops) 2 09-02-2008 10:48 AM
Whirlpool double wall oven Diana Oven Repair (including Ranges and Cooktops) 0 02-26-2008 10:28 AM
Electric Double Wall Oven Warm, not Hot jcrump55 Oven Repair (including Ranges and Cooktops) 2 11-12-2007 08:36 PM
