oven diagnosed with bad control board, part # W10108100. Easy to install myself? Do you have installation instructions? Thank you! Chris
Originally Posted by: crutledg oven diagnosed with bad control board, part # W10108100. Easy to install myself? Do you have installation instructions? Thank you! Chris Chris, The ERC/clock is a basic repair, not too hard, doable with basic hand tools, It would be worth a shot, and save quite a bit on the labor charges. 1) Disconnect line cord and slide unit out. 2) Remove all the screws holding the upper half of metal backpanel, remove panel 3) Carefully remove ERC and mounting brackets from control panel. 4) Attach new ERC/clock to brackets 5) Switch wire harness connectors from old unit to new unit 6) Install new ERC into control panel. Reverse procedure and test ERC/clock operation. [part]AP3996715[part] Good Luck, :) :) :)
WOW. EZ! 27 minutes and saved $168 by installing myself. Found online at Sears for $108
Thanks!!
Originally Posted by: crutledg WOW. EZ! 27 minutes and saved $168 by installing myself. Found online at Sears for $108
Thanks!! You're quite welcome, Glad you're up and running. Good Luck, Happy Holiday :D :D :D
