| » Kitchenaid Oven has power but will not heat up |
Model Number: KDRP407HSS13 Brand: Kitchen Aid Age: 1 - 5 years
We have a Kitchenaid oven model KDRP407HSS13. Last year I had an error on the display and after some research, I replaced the fuse behind the control panel. That fixed that problem and it has worked for several months. Now the oven gets power to the contol panel, the oven lights work and there are no errors on the display. When I select any baking option and hit enter, the oven does not heat up. I read on this forum that there is another thermal fuse behind the oven just above the convection fan (which I have located). Can I bypass the fuse using a jumper wire to see if that is the problem before I order a new fuse or could it be another issue? Ads By Google Related Models |
Does it Broil?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Most likely the problem is a bad oven shut down thermal fuse (#37 on the diagram).
You can bypass it for the test purpose only, but it is more save to test the fuse for continuity. - The thermal fuse Part number: AP3055316 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KDRP407HSS13 30" Kitchenaid Free Standing Range Dual Fuel | AppliancePartsPros.com Gene.
__________________
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter.
__________________
Happy Thanksgiving! Gene.
__________________
It's been almost a year since our last conversion. You did not have time to fix it or it broke again?
__________________
| Display Modes | |
| KitchenAid Oven Will not heat | JPratt | Oven Repair (including Ranges and Cooktops) | 8 | 10-29-2011 01:52 PM |
| Kitchenaid Oven will not heat up | TAGS | Oven Repair (including Ranges and Cooktops) | 0 | 07-05-2010 04:56 PM |
| Oven has power but no heat | hsackson | Oven Repair (including Ranges and Cooktops) | 1 | 04-05-2010 05:40 AM |
| KitchenAid Oven won't heat up. | tech_58 | Oven Repair (including Ranges and Cooktops) | 1 | 05-30-2009 07:28 PM |
| Have Power but won't heat, Burner or the oven | Drainpro-Joe | Oven Repair (including Ranges and Cooktops) | 0 | 04-20-2009 07:50 AM |
