My Dacor dual fuel range door protrudes 1/2 inch at the top from each side. I have been fighting with my home warranty company and their appliance technician to get the door fixed correctly so it does not stick out. Heat escapes from the oven and has cracked the handle and front bezel. Can anyone send me photos from both sides of their unit showing that the door does sit flush against the frame of the unit? I have contacted dacor and they said the problem needs to be fixed but getting that accomplished has not happened to date.
