I replaced the main (outer) bake element with a new one purchased from AppliancePartsPros.com. It works beautifully. The slo cook (inner) element is not working, even with the SLO COOK switch on. The element checks OK for continuity. Resistance in the element is 55 ohms. I've also had an appliance repairman check the element. He says it is good. What should I check next to get the slo cook element to work?
