hoof140
#1 Posted : Tuesday, November 23, 2010 10:01:05 AM(UTC)
hoof140
After oven preheats, it does not relight just sits there. But not always, it sometimes does what it is supposed to do. I have replaced the thermostat and ignitor. Seems like turning on a burner on top helps????
Joe / APP Team
#2 Posted : Tuesday, November 23, 2010 10:51:27 AM(UTC)
Joe / APP Team
Hoof,
Did you ever have an "F" code in the display ?
Did you recently put your range in a "self Clean " mode ?
Does your broil burner/igniter work, properly ?
I'm thinking a few possibilities,
1) In some cases, after a self clean cycle, the oven temp sensor becomes
eratic ?
Part number: AP4009456
2) A loose wire connection, between the igniter and safety / bake valve, or
from the safety / bake valve to the terminal block.
3) A possible intermittent switch in the safety valve itself.
Part number: AP4098213
I don't see why turning a top burner valve on would assist the oven burner in it's ignition procedure,(two separate circuits/components) other than the fact that both need a neutral and or path to ground to complete the circuit,
That's why I reccomend you check the connections / wires to the bake igniter,the bake valve, and back to the neutral leg of the terminal block, first.
Good Luck.
hoof140
#3 Posted : Sunday, December 5, 2010 6:55:01 AM(UTC)
hoof140
Thanks for the response. I checked all the electrical connections. They seem fine. The broiler works just fine. The bake {lower} ignitor lights up red hot, but it seems like for whatever reason the gas is not kicking on ????? Thanks
Joe / APP Team
#4 Posted : Monday, December 6, 2010 6:26:35 AM(UTC)
Joe / APP Team
Hoof,
We need to go farther,
Even a new igniter could be weak, out the box.
Do you have access to a multi meter and / or clamp on ammeter ?
Part number: AP3873826
You'll need to check the voltage to the igniter, from the control board.
*** These are live voltage tests, Be Careful ***
*** Unplug power cord, between tests ***
Disconnect the wires to the igniter ,
Place your meter probes across the 2 wires from the control,
Program a bake cycle and set temperature.
In a few seconds you should have a reading of 110 to 120 VAC. on the wires from the control.
Reconnect wires,
Re program a bake cycle,
Within 60 seconds of the igniter starting to glow,
You should be able to read a minimum of 3.2 amps, with the ammeter clamped around one of the igniter wires,
Or, a minimum of 3.2 VAC across the terminals of the bake burner valve.
Low amperage draw, or low voltage at the bake burner valve, indicates a weak igniter, or low voltage from the control.
Since you've checked all your wiring, I'm guessing, a weak igniter out the box.
Another Quick easy check,
Be careful, don't damage anything...
Switch the igniters, Broil igniter to the bake burner, and vice versa.
If we have a weak igniter, the problem will appear at the broil burner and the bake burner should work.
:cool: :cool: :cool:
Maytag oven problem (Oven Repair (including Ranges and Cooktops))
by kapittma 8/28/2012 9:20:45 AM(UTC)
Maytag Oven Problem (Oven Repair (including Ranges and Cooktops))
by FI62 8/3/2009 9:13:05 AM(UTC)
Maytag Oven problems (Oven Repair (including Ranges and Cooktops))
by kevinw3 6/15/2009 12:04:33 PM(UTC)
