The clock and oven systems do not work. The cooktop works and the oven light works but the control panel and broiler, bake, clean, timer - all the touch commands do not respond. Is there a reset switch somewhere on the range? Hopefully it doesn't need a new control panel... how do I test that?
I cannot find any info on the given model number, please check it. |
THIS FORUM IS DEAD!!!!!!! |
Oddly enough the model # is correct - just double checked. The good news is that it is working now. I shut down the system at the power box in the garage, confirmed that there was no juice and then opened up the front of the stove at the control panel. Checked all the wires and made sure that there was a good connection, buttoned it up, hit the switches in the garage and it is working fine... go figure. Thanks for your help.
