Appliance Repair Forum
Appliance Repair Forum (
-   Oven Repair (including Ranges and Cooktops) (
-   -   GE Dual Wave Microwave System- original to house- 1986J (
Rochelletx65 11-11-2008 04:44 PM
The microwave started sparking a couple of nights ago, leaving burnt looking spots inside- still works, but there are tiny specks inside of wall that look burnt out. Timer on oven doesn't work, neither does self cleaner. We are moving soon and need to replace to sell house. What is the most economical option for us? Thanks so much!! Not very happy!!:confused:
Gene 11-12-2008 02:16 PM
I'm afraid you do not have much choice but replace the whole thing. The timer is no longer available for this model and arcing inside the microwave means serious problems with the cavity surface and, very possible, the magnetron.
rozman 03-08-2009 10:30 AM
hi. i have a vintage 1985 GE dual wave system also and my light bulb in my microwave is not working. do you know where the light bulb is and do you have a manual that tells you how to replace it?
Gene 03-08-2009 04:39 PM
In order to provide moist accurate advise we need the complete model number of the microwave.
rozman 03-09-2009 07:57 PM
model number
hey. the complete model number is: JKP67G002BG. thanks
Gene 03-10-2009 02:27 PM
In order to access the light bulb in the microwave you have to open the control panel. The light bulb is a regular 40 Watt appliance bulb.
Here are the break down diagrams and Replacement parts for GE JKP67G*02 |
rozman 03-11-2009 06:52 PM
thank you so much for sending me the diagram.. this will help me a bunch and will come in handy. thanks again
Gene 03-12-2009 03:07 PM
Therese 04-12-2009 06:04 PM
New baking element
Does anyone know if the baking element for the GE Dual Wave II is the same, regarless of model number? My oven's taking a long time to heat up and would not bake anything on the bottom so I'm assuming it's the baking element that needs replacing (Model #JKP78G0K4).
The unit is almost 20 years old and we would like to use it for another year before replacing the whole thing. Thanks for your help.
Gene 04-13-2009 01:48 PM
Does the Bake element get red hot when you use it? If yes, then the problem is a bad control board which is unfortunately no longer available.
- The part number for the Bake heating element is AP2031031
Here are the break down diagrams and Replacement parts for GE JKP78G*K4 |
