Discuss
GE Dual Wave Microwave System- original to house- 1986J
 in
Originally Posted by rozman hi. i have a vintage 1985 GE dual wave system also and my light bulb in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Dual Wave Microwave System- original to house- 1986J
  #11 (permalink)
Old 07-27-2009, 10:23 AM
Junior Member
lwsears is on a distinguished road
Default Light bulb replacement
Quote:
Originally Posted by rozman View Post
hi. i have a vintage 1985 GE dual wave system also and my light bulb in my microwave is not working. do you know where the light bulb is and do you have a manual that tells you how to replace it?
I have just worked on a 1983 model and found that if you pull the unit out away from the wall you will find a little cover with one screw in it, remove the cover you will find the bulb.
Ads By Google
  #12 (permalink)
Old 09-16-2012, 11:47 AM
Junior Member
dwbrooks is on a distinguished road
Default Hi
We have the GE Dual Wave Microwave System as well. The heating elements in the oven are heating slowly. We know we will have to buy a new system soon but for now we are interested in giving this one a bit more life. Does the heating element part ( AP2031031) apply to both the top and bottom elements? The elements do not get red hot when we turn on the oven -- just kind of warm.
Model # JKP62G0K3
Thanks! Dominique
  #13 (permalink)
Old 09-17-2012, 06:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dominique,
If the both, broil and bake, elements are not getting red hot, then the problem most likely is a bad oven thermostat and/or the oven selector switch. Unfortunately both of them are no longer available.
You may want to check the circuit breakers for the oven and the wires inside the control panel and on the back of the oven. Otherwise it's time for a new oven.
Here are the breakdown diagrams and Replacement parts for General Electric JKP62G*K3 Electric range | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #14 (permalink)
Old 01-08-2013, 08:04 AM
Junior Member
terry_gilman@comcast.net is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
In order to access the light bulb in the microwave you have to open the control panel. The light bulb is a regular 40 Watt appliance bulb.
Here are the break down diagrams and Replacement parts for GE JKP67G*02 | AppliancePartsPros.com
Gene, I saw you posting on replacing the light bulb in this particular GE microwave. I have theould you GE JKP67G*J3 with the same problem. Could you send me instructions on how to open the control panel so I can get to the bulb?
  #15 (permalink)
Old 01-08-2013, 02:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The light bulb can be behind the top grill or behind the control panel. Unfortunately I do not have more specific instructions for this model.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dual Wave II microwave Model #JKP78G0K4 BG wont' heat JayHan Microwave Repair 0 02-08-2010 02:21 PM
GE Dual Wave II - seems low wattage now nickHsac Microwave Repair 0 01-16-2010 09:01 AM
GE dual wave microwave lwsears Microwave Repair 0 07-27-2009 10:17 AM
GE dual wave microwave system rozman Microwave Repair 0 03-09-2009 08:04 PM
GE Dual Wave II - Microwave "popped" gpdreier Microwave Repair 6 10-08-2008 09:27 PM
