Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   setting replacement glass for door on range (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/144204-setting-replacement-glass-door-range.html)
mfs 11-20-2010 11:44 AM
Ordered new glass for front of door for 30 inch Whirlpool stand alone ceramic oven. Having difficulty placing the glass in front of door within frames on either side of pull down door.The frames are attached to the bottom frame. that sits atop bottom pull out drawer. Not sure the two frames on the side of the door fit properly as I cannot get glass to rest evenly on the botton frame before screwing in the top oven door handle frame that secures the glass and the two side frames.
Any help is appreciated, either written or verbal.
Marc
denman 11-21-2010 03:40 AM
Perhaps this will help
https://secured.whirlpool.com/Servic...LE/8178042.pdf
kayakcrzy 11-21-2010 04:30 AM
Marc
It is alway best to take the door off to replace the front glass!! Tom ww.********************************************
GregoryGay 02-20-2011 06:32 AM
Did you get your glass on? I am experiencing the same issue. What did you do to get it on?
